Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Une imprimante 3D fabriquée par Flashforge.
Nozzle disconnected itself from heater/extruder during print
I replaced the 0.4mm nozzle with a 0.6mm nozzle. It printed fine for 1/2 the print and then apparently disconnected itself from the print head/extruder. It no longer seats electrically and I can't re-seat it due to the resistance from the filament. So...I can't remove it because it won't heat up due to not having any electric contact.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
My topic on reddit might be use full? It happened to #metoo
EDIT; THE PART HAS BEEN FOUND: https://www.thingiverse.com/thing:486580... Thanks to: https://www.thingiverse.com/jnkw279
Hi everyone,
Recently, my Adventurer 3 almost exploded during a print job. After some investigation, I discovered that a small plastic part from the extruder (as shown in the attached picture) had snapped.
I contacted Flashforge support, but unfortunately their response wasn’t very clear — either due to language issues or a misunderstanding. They sent me a link to a replacement part, but it turned out to be the wrong one.
So now I’m turning to the community: Has anyone else experienced this issue with this particular part? If so, how did you resolve it? • Did you manage to find a correct replacement part from Flashforge or another vendor? • Did you perhaps model it yourself in CAD and print it? • Would anyone happen to have an STL or other 3D model file for this part?
I’m even considering redesigning the part and having it CNC machined from metal or a more durable material than plastic.
To be clear: my printer has only been used for a total of less than 3 months (just under 600 hours), and it already failed — which is disappointing for such light use.
Any help, tips, or shared experiences would be greatly appreciated!
Also Not Looking for a paid service, also i have friends with printer and as you can see i did a quick and dirty temp fix using super glue. so i can try to print it tomorrow myself just not into reinventing the wheel ;-).
https://www.reddit.com/r/FlashForge/comm...
Indice 0
Ajouter une réponse
Rick in Norfolk sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 22
Total : 370
