Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le OnePlus 9 5G est un smartphone de milieu de gamme sorti en mars 2021. Successeur du OnePlus 8, il est équipé d'un écran Fluid AMOLED de 6,55 pouces à 120 Hz et fonctionne avec un chipset Qualcomm SM8350 Snapdragon 888 5G.
LE2117 Battery replacement options?
Hi, looks like the BLP829 battery sold for the Oneplus 9 5G does not have the Tmobile variant (LE2117) listed as a compatible model. I haven't had much luck finding a Tmobile specific battery for this device, does anyone have any recommendations or know if the BLP829 will work on an LE2117?
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
1 commentaire
Hey Zed I currently need to replace my LE2117 & OnePlus refuses to do it even with me offering to pay the labor and parts fees. I was wondering if the replacement battery is still holding up? And if so, did it seem new after initially installing it?
par
Ajouter un commentaire
2 Réponses
Solution retenue
Hi, the BLP829 battery will not fit in a model LE2117 for T-Mobile in the US. You may need to find a different battery model that is compatible with your device. You can use the Oppo BLP821 battery2, which has the same voltage and capacity as the BLP829 battery, but you should check the dimensions and connector type before buying it. Alternatively, you can contact OnePlus customer service and ask them for a recommendation or a replacement service.
Indice 3
3 commentaires:
Thank you, i ordered the Oppo BLP821 and it fits and functions perfectly.
par
From where did you purchase it?
par
Thank you Zed for confirming the BLP821is the right replacement battery for my One Plus 9...LE2117 phone. It's definitely saved me a lot of time and frustration.
par
Hi Zed, the BLP829 battery won't fit in a model LE2117 for T-mobile in the US. You can use the Oppo BLP821 battery which has the same voltage and capacity as the BLP829. I hope this answer can help you.
Indice 1
1 commentaire:
Thank you Holly, for that valuable information because I was about to purchase the wrong replacement battery. I research to find the right replacement battery and Google said I needed the BLP829. I am glad I read the comments before I place my order.
par
Ajouter une réponse
Zed sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 45
Total : 2,509
