Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lancé en juillet 2020, cet Inspiron dispose d'un écran 15,6 pouces 1080p, d'une large gamme de processeurs Intel, de mémoire vive DDR4 évolutive et d'une sélection d'anciens ports externes diversifiée.
Why my laptop is over heating?
My dell laptop gets heated very soon.
I run HARDWARE DIAGNOSIS and got these following errors.
Sensor-error accessing thermal sensor skin status = invalid parameter , error code: 2000-0173
Sensor - error accessing thermal sensor skin status = invalid parameter DIMM A status = invalid parameter.
Error code: 2000-0173
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
The fan is spinning?
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Based on your description, I will try to answer.
  • It can be caused by wrong Bios version/obsolete Bios, to resolve update your bios or find the suitable bios for that board.
  • It can be caused by broken temp censor.
  • It can be cause by clogging air fan.
Hope this will help to resolve your problem.
Indice 1
Just to chime in on the great answer above. The inspirion is a budget laptop, great system and the more budget sensitive the lower dollar figure rolled into production of this off the assembly line. The design is not perfect and dust will become a challenge even down to the connector that you connect for power. A particle, in my past history, has kept the charge from fully taking place. One day if they decide to use modify things, they should use the power cord for the Latitude. Used one for work and my woes went away. Become ninja like in terms of breaking the system down and cleaning. use anti static mat and appropriate tools and have service manual close by and ensure your grounded when on the interior. best EM TEXAS
Indice 0
Ajouter une réponse
Sandeep Chetia sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 515
