Aller au contenu principal
Annoncé le 13 octobre et sorti le 23 octobre, le smartphone vedette 2020 d'Apple est doté d'un écran OLED de 6,1 pouces, d'une caméra arrière à triple objectif avec LiDAR et de la 5G. Il succède à l'iPhone 11 Pro.
12 pro booty loop after board split
Today i get one 12 pro with no imei, no modem firmware. I heat it on preheater 180° after flash was imei back, but was only searching. I Split the board and now the upper board have bootloap. Current Reading with usb is typic, start on 0,2A ->0,8A->1,6A->2,4A and restart, cycle is cca 5second. Any idea what can be? Reading Current direct power on battery connector is till 800mA
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
The iPhone 12 can boot with just the top board but I don’t think the 12 pro and 12 pro max can. Your readings are showing the phone to be booting normally until it detects the bottom layer is not sending any data to the CPU so it is re-booting.
Indice 1
2 commentaires:
I was also thinkink the missing bottom board can make problem. But after i try iphone 11, and only core board is booting to systém. Then i was think 12 pro also starting alone.. I allready order "isocket" then now i wait... Thanks
par
I get today this i socket, also when is lower board connected still bootloop. Any idea?
par
Ajouter une réponse
VojTech sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 105
