Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La Xbox originale est le premier système de jeu vidéo de Microsoft à connaître une grande popularité. Elle se présente sous la forme d'un boîtier noir facilement identifiable, portant l'inscription "XBOX" sur le dessus et à l'avant. Réparer cette console est facile avec des outils courants.
Xbox (1.0) Burnt out Resistor on PSU Board.
Hello, I'm new to electronic so apologies if this is a foolish question. I have a burnt out Resistor on my power supply as seen here.
Looking at another Xbox I believe the bands on the resistor are Yellow, Brown, Orange. Indicating a 41 kΩ. The problem is I don't know the wattage or the tolerance. Does any one know what I would need to buy to replace this burnt out resistor to prevent it from burning out again? Thanks for taking the time to read and reply.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
1 commentaire
I'd love to know if the original issue was resolved by replacing this resistor. I'm also curious if replacing the other components that appear to be surrounded by burnt board ended up being necessary also. Specifically, that ceramic capacitor and additional resistor to the right of R13, as well as whatever component is to the right of that but hidden a bit.
par
Ajouter un commentaire
1 Réponse
Solution retenue
@samdonald I suggest that first you remove the complete power supply board. Then remove the resistor. Measure it to verify that it is a 41kΩ when it is out of circuit. Clean the board of any burned residue with some cotton swabs and isopropyl alcohol. Inspect the other components closely (focus on the diodes in that area) and check the bottom side. There are components as well that may get damaged. For the Through-the -hole resistors the size of an axial resistor is relative to its power rating. Measure the physical length of the resistor body. Then check this chart
from here for the wattage.
Indice 2
4 commentaires:
Okay, i'll have to measure it tomorrow if I can find it. It's my understanding (after looking over some google forums) that I can buy a larger resistor with a higher Watt and that will be okay.
Is this something I should look at? Would A higher Watt provide more protection from the load that doomed the last one?
And on another note I'm just color blind. The bands go Yellow, Brown, Orange then Gold meaning there is a tolerance of + and - 5%
edit* Just so people know the specs if some one else comes looking
Resistor Place on board: R13
Resistor Bands: Yellow, Brown, Orange, Gold (41k +-5%)
Dimensions: About 7 MM (1/4 Watts)
Thanks for the help. I'll make sure to have ham this thanksgiving.
par
@samdonald that is correct. With the color bands you describe, the resistor is a 41 k Ohms 5%
Sure you can go higher on the wattage but no it does not provide more protection. It just means that the resistor can use more power. There is a reason why it "blew up". It could be a resistor failure, or a short to ground in the circuitry. That will be difficult to repair since I haven't seen any schematics for the PSU
par
I think there is some schematics floating on the orginalXbox reddit, but it's set to private. I've been trying to get in there over the last week, but I think me being brand new to reddit is seen as a red flag.
In any case I'll spend a couple bucks on a resistor if that doesn't work I can always just buy a PSU online, or better yet another broken xbox to add to my tower of doom! Thanks again for the help.
par
@samdonald yeah, looks like it's set to private and you'll have to get permission. PSU's for it are inexpernsive and will definitely be an option.
par
Ajouter une réponse
TheGreyKeyzard sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 28
Total : 939
