Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Un ultrabook 2-en-1 professionnel à écran tactile, sorti avec des processeurs Intel Core de 5e génération en 2015.
My keyboard will not work or my touchscreen. can't find help
How do i fix this keyboard issue? I've tried updating ect...
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
Hi @tamamahoney,
By "... tried updating ect......" did you also uninstall the drivers and then restart the laptop and then let Windows reinstall them?
Not sure if this was included in the etc.
Have you tried plugging in a USB keyboard and checked if that works OK?
par
Ajouter un commentaire
2 Réponses
I like jayeff's USB keyboard suggestion and would try that first. Also a USB mouse.
Perhaps you have already done so, since you say you've 'updated' etc.
Are your keyboard and touchscreen currently recognized by your Device Manager? Does it
say they have drivers and are functioning correctly?
Jayeff's device removal and reinstall suggestion is worth trying if you have not.
Have you gone to Lenovo support and let them try to detect and install drivers for your
device?
One weird thing just to try because it sometimes fixes inexplicable problems is to test
for a bad ram stick. I know that sounds unlikely, but it takes little time to test and just might be the culprit.
If you've done all this and things still aren't working, here's one more
last-ditch suggestion (a little hazardous these days in terms of malware):
You could get hold of a driver updating disk or flash drive and run that. I still use a somewhat dated
version of Snappy (thoroughly scanned for malware and not internet connected)
to recognize devices and install obscure drivers, especially when putting in a brand new OS.
Sometimes drivers can be incorrect even if Windows doesn't catch that. (Ebay lists DVDs and flash
drives you can buy preloaded with Snappy drivers, btw.)
If everything is recognized and running the 'right' drivers correctly and things
still aren't working, you may have a hardware problem. But I'd only move onto that
after trying every possible software fix.
Indice 0
I also had this problem. All you need to do is use the onscreen keyboard, tap the WINDOWS key then the r key. That will open the command prompt. Type in the little command window "devmgmt.msc" and hit enter. Go down to "keyboards" in the device management window, find the "standard ps/2 keyboard" and open it. Select the correct tab under drivers, and select "uninstall". Then reboot your system. The keyboard will automatically reinstall, and should work fine after that. Then run Windows update and select "additional updates" and download everything available. That should stop the issue from reoccurring. Hope this helps.
Indice 0
Ajouter une réponse
Tama Mahoney sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 298
