Hall Effect stick replacement.
The stick that holds the thumb sticks on the right has been broken on my Gulikit KingKong 2 Pro. I just want to replace the hall effect stick. Desolder it and replace it with a new one. Does Gulikit or ifixit provide the hall effect stick alone?
1 commentaire
Gulikit do sell replacement sticks - I contacted their support email address and asked. In fact even though I'd asked for one replacement stick I received two what what I considered quite a nominal fee.
There is, however, a caveat - like most modern consumer electronics lead-free solder has been used, and removing the existing stick from the board is by no means straightforward given there are 8 solder points to deal with.
I found that snipping off the legs between the controller and the board was best, and having a second pair of hands available to keep things steady as the pin and solder remnants are removed.
It is however still far easier to replace than Dualshock or Xbox sticks, so there is that.
par Glis
