Samsung smart TV (ue50tu8070uxzg) stuck in boot loop
Edit: I.'ve added some more recent information at the bottom.
Original question:
My TV started getting stuck in a boot loop. The standby LED blinks twice, the LCD turns on for about a second (no picture) and then turns off again and the process restarts.
It's an issue that I've seen in other places on the web and multiple solutions are proposed. What seems to work for me is to tweak the ribbon cable connecting the LCD to the motherboard, but it doesn't seem to work for the long term.
What I've done:
- Open back cover, remove ribbon connector and turn on TV. The screen stays on but there is no picture obviously.
- Place a piece of sticky tape on a few of the ribbon cable pins (a fix I found in some online video), replace the ribbon cable and turn on the TV. Typically I get a picture but it's only noise. Covering different pins give slightly different results.
- Remove the tape altogether and reconnect the ribbon cable. Turn on tv. Screen works again, though no idea why. At this point I put everything back together and thought it was fixed (there are a few blackish horizontal lines on the screen but it's not so bad). [EDIT: this doesn't seem to work anymore, or perhaps just requires too much patience. See below for more information.]
- One hour later, turn on TV to realize the initial issue is occurring again. Repeated the whole operation and last time I checked it worked, though I'm afraid perhaps not for long.
My questions:
- Any input/information regarding this issue would be highly appreciated.
- Specifically, it seems to me that the ribbon cable may be the culprit here. Should I try replacing it? Other ideas on how to perhaps fix it? I've tried wiping it gently but that doesn't seem to do anything.
- Any idea why the heck the TV works again after sticking tape on the pins? Could it be the contact isn't snug enough? Should I try sticking tape at the back of the cable to increase the pressure when latching?
Thanks for any ideas/answers. TV is just above 2 years old btw, issue started just as the warranty expired of course...
[EDIT] I'm sorry I meant to post pictures but time flies.. Been using the TV for a couple of months now using the tape off trick, a bit of a pain but works every time:
What I need to do is tape off the cable and turn on the TV. I get a picture but there quite a few parasite horizontal lines. After a few minutes the screen starts turning purple, starting from the center and extending gradually towards the edges. When the screen is all nice and purple, I turn off the TV, remove the piece of tape and turn it back on, then it works until the next time I turn it off.
I've been looking to try and replace the ribbon cable but no luck finding one online so far (ref sfpcx495g-002). Still unsure what is the root cause (cable or LCD)
Here is the ribbon cable with the piece of tape
Here the screen starting to turn magenta
Here completely purple after a few minutes
I'm sorry I meant to post pictures but time flies.. Been using the TV for a couple of months now using the tape off trick, a bit of a pain but works every time. Also I've been looking to try and replace the ribbon cable but no luck finding one online so far (ref sfpcx495g-002).
[image|3123092]
[image|3123094]
[image|3123093]
par wawrzeniec
@wawrzeniec looks good and it is working, which is the main objective. The Tape-off is tricky since it could really be anyone of the data lines, sometimes even multiple on different pins. Is's pretty time consuming and frustrating to figure it out. You did a good job there!
par oldturkey03
