1995 OBD 1 Toyota 1800 no spark
95 Toyota Dune Buggy late 80s early 90s 1800 cc getting no spark OBD1 what could it be? Everything seems to be in spec but just cranks.
Indice
0
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 3
Total : 30
Distributor ignition system for spark or is this '95 Toyota using EFI (electronic spark and electronic fuel injection)? Which model was the engine adapted to dune buggy use? Any electrical/electronic mods to engine?
par F Dryer
Fuel injection ef1 1800 we believe that was adapted with a kit and can’t find the numbers
par Dayna Devencenzi
Again. Distributor ignition or EFI electronic ignition system? Distributor ignition, whether using contact points and ignition coil or electronic distributor using electronics instead of contacts, distributor ignition systems are old school but relatively easy to troubleshoot. Electronic ignition systems as part of electronic fuel injection requires a crank sensor generating timing signals used to operate the ecm/pcm to operate the entire EFI system. Three different ignition systems and you haven't described which one is used.
par F Dryer
