Aller au contenu principal
Marshall Stockwell Bluetooth speaker
5 questions Voir tout
Can I use my Marshall Stockwell without the battery?
The battery on my Marshall Stockwell does not retain charge anymore. I removed it and i will refurbished it with a company that dedicates to this. Can i use it without the battery in the meantime?
Update (07/02/23)
After posting this question here, I contacted Marshall through their chat support.
They told me that removing the battery and using the speaker connected to the power supply charger would not cause any damage.
I decided to give it a try, and I'm happy to report that it works perfectly.
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
How do you connect the charger to the speaker directly? Is it simply an usb connection?
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Check first your power supply if it still working.
  • Remove connecting terminal of your battery and check the positive and negative terminal wires if there's still voltage output. I yes, may your battery was already damaged (Replace it). If no voltage output or has a lower voltage output, replace your power supply battery charger.
  • If you want to use it without the battery anymore, you can use a power supply that has the same voltage/current rating to your charger/battery. Connect the power supply directly to the battery terminals after removing the battery.
I hope it can help.
Indice 2
1 commentaire:
Thanks for your reply, James!
par
Ajouter une réponse
Fokka85 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 16
30 derniers jours : 62
Total : 850
