I need a new battery HP 15-n092nr. Help.
Pls help a beginner replacing parts. Help with my HP Pavilion laptop, model 15-n092nr.
1) How to remove the back cover.
2) How to replace the battery.
Thank you.
Thank you.
Have a look at HP’s official service manual. It will have all the details on how to take things apart.
If you’re just replacing the battery, that’s easy. You don’t even need to take the back cover off for that. There should be a pair of sliding switches on the hinge side of the bottom cover. If you push both switches inward, the battery should be unlocked and you can just pull it out.
I can't believe how quickly helpful folks like you are answering. This is the first time I've ever put anything onto the web. Thank you Alisha C. Marti
@marti99759 Absolutely! Glad to be of help! Let us know if you run into anything weird!
It would appear that to replace the battery on your model laptop you don't need to open the laptop or unscrew anything.
There should be a switch or a couple of buttons to release the battery so you can remove it and then just replace it with a new one.
THANK YOU. I am a novice, so this really, really helps. Thank you jeffmcc. Marti.
@marti99759 No problem! I hope this helps!
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 20
Total : 133
