@mili93536 could be a bad switch or a bad motor. If you can roll the window up and down, from the drivers control panel, it is most likely the passenger switch. If you can't it's most likely the motor/wiring.
Of course, since the BCM is controlling the windows, there are many of things you can check.
Here Cruze Fixed And Moveable Windows is all you ever wanted to know about the windows, moveable or not ;-), on your Cruze. It'll tell you how and where to test as well as how to replace.
Now, if you get stuck anywhere, or if there is anything that is unclear, post some good pictures of that with your Question. That way we can see what you see and hopefully get your window fixed. Ajout d'images à une question existante
A voté
Annuler
Indice
0
@mili93536 power windows I assume?
par oldturkey03
Yes! Sorry i should’ve been more specific
par mili
