Right Joycon Not Detected in Handheld mode
I've seen several people with similar issues online but all seem to be resolved with just "clean it." and nothing else being suggested but I've gone well past "just cleaning" and am still coming up short. Please see below for additional details of what i've done so far to attempt to fix this issue.
Device
Right White Joycon that comes with Switch OLED model
Device State
Syncs with any device without issue
Charges from the Switch without any issue
Works as expected except when attempting Handheld Mode
Testing
Using OLED model Joycons came with-
Left White + Any other one of my different Right Joycon will work in handheld
Using Standard Model
White Right Joycon will sync but still will not work in handheld. All other Joycon combos I own work just fine in handheld with this model.
Fixes Attempted
- Confirmed Switches and Controllers are Updated to Latest version
- Can Duster over rail connections
- Disassembled Right White Joy Con and cleaned connections with alcohol and let dry
- Full replacement of Right White Joycon rail
From all my testing it seems to be something wrong with the joycon specifically and nothing to do with the connectors or Switch since this problem carries over across multiple models. Any suggestions would be greatly appreciated.
2 commentaires
Info needed:
When you dock it on handheld mode, does it charge?
Flip it backwards and dock it on the left side (the buttons facing the back of the console, but up is still up and down is still down). Does it charge? Does it sync?
When you dock on handheld mode, does it stay wirelessly connected, or does it disconnect the wireless and just not connect?
Have you tried docking this specific joycon on a different switch?
par Justin Castle
Yes, it charges in dock
Yes, it charges if i flip it and put it in the left rail
When docked or handheld mode the Right Joycon registers as Wirelessly connected
par Bret K
