Re-Use Speaker? Adapter needed
Hi,
myself disassembled some HP Wave, sadly, and I thought to re-use the speaker.
I mean, it offers some screws/mount and is pretty decent sound wise, so why not?
However, it has just some 2 pin cable/plug.
The potential candidates where it should get built in however do offer some 4 PIN speaker slot on board, where the plug even is little bigger.
Can i manually pin those into some 4pin connector? Is there even some adapter (cable)? Myself would need to extend length either way just a bit.
Sadly myself is just finding some stuff in regards to buzzers while googling, and this doesnt help.
Personally i do find it curious that this monster has just this 2 pin connector for Power AND audio....
Thanks
EDIT:
How the 2 cable/4pin adapter looks like:
How the speaker port looks like, another cable/speaker being connected.
Just from plug size its even around twice as big.
EDIT2:
6 commentaires
@toddk80 Like many speakers, there is no amp built into this one. It is driven by an amplifier. The two connections are Audio (mono) and Ground, similar to what you would see on home theater speakers.
par Andrew S
@andrewsawesome First of all, thanks for the speedy response on this.
Yes, it indeed remembers me to some regular non-PC speaker connection towards the station.
However im no audio expert, so would it work with manual wiring, or not?
I mean, the HP Wave simply connected it and did the AMP job, no? So why cannot the new PC do the same?
Is there some cheap adapter which i can buy?
par Todd
@toddk80 there is most likely not a ready-made adapter. You probably have to make one yourself. Ost some pictures of the connector where it was connected to and where it is going to be connected too. Also, a picture of the wiring on the speaker might help. Post those with your Question. You'll have to edit that.
Ajout d'images à une question existante
par oldturkey03
@oldturkey03 Myself just updated the original message with pics. Thanks
par Todd
@toddk80 were you going to remove whatever is connected to the bottom connector? If so, you can most certainly replace it with the wires from the smaller one. Here is the issue, the black wires look like you have 2 speakers connected, so possible a "stereo" output. We really need to know what motherboard you are using. The model for the boards should be printed on it. Post some good pictures of your motherboard with your Question.
par oldturkey03
Afficher 1 commentaire en plus
