Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
5 commentaires
What part of the motherboard is not working? Can you give more details of the issue?
@kumailkazmi you really need to give us lots more information if you expect some help with this. At minimum we need to know why you think that your motherboard is not working properly. What make and model motherboard? What does or does it not do? What have you checked and what have you tried to fix this?
@amiribnmohammed if you need help with this you want to give us all the information. The fan did not spin is just to vague. What does your computer do? It overheats? Did it overheat because the fan didn't spin? Did you replace the fan? What did you check?
The only logical answer based on your question would be : Replace the fan.
5 commentaires
par honakrisi
par oldturkey03
=== Update (09/17/23) ===
par Amir Ibn mohammed
par oldturkey03
Yes my mother board is not working
=== Update (10/01/23) ===
Yes mother board not working
par Rambabu kushwaha
