Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La montre connectée quatrième génération d'Apple, avec connexion aux réseaux mobiles en option, mise sur le marché le 21 septembre 2018.
Putting an LTE screen on a non LTE body (Apple Watch 4 Nike)
Hi Everyone,
I need some help.
I have an Apple Watch Series 4 Nike 44mm. I got it as a present (it was used), worked perfectly until my son managed to drop it and cracked the screen.
I found an LTE screen on ebay, and I am wondering if it will work on a GPS only model. I don't care about apple pay and stuff like that, I use the basic functions of the watch (Strava, step counter, looking at notifications when cycling etc.) hence I don't want to spend 100 euros on a new screen, happy to spend about 50-60 for a used one. Yes I can do the swap myself.
Thank you for the answers!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
@gezamolnar With the knowledge that the replacement screen from iFixit works with all models, this screen should work with yours. You might want to consider buying the fource touch sensor gasket in case you damage yours. I would also recommend buying the iFixit pre-cut adhesive for the screen adhesive, but you could use a liquid adhesive instead or cut your own adhesive tape if you prefer.
Let ne know if you have any further questions
Image Replace a damaged or malfunctioning force touch sensor that fits between the display and rear case of a 44 mm Series 4 Apple Watch.
Produit
Apple Watch (44 mm Series 4) Force Touch Sensor Gasket
$12.99
Image Replace an adhesive strip compatible with the 44 mm case Series 4 or Series 5 Apple Watch model A1976, A1978, A2008, A2093, A2095, and A2157.
Produit
Apple Watch (44 mm Series 4/5) Screen Adhesive
$6.99
Indice 2
1 commentaire:
Thank you very much, I'll do that! :)
par
Ajouter une réponse
Géza Molnár sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 8
Total : 148
