Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xiaomi's Mi 6 smartphone was released in April 2017 with a 3350 mAh non-removable battery and dual 12-megapixel main cameras. This device has either a glass or ceramic backing and includes a water-resistant coating.
How to replace screen
Répondre à cette question J'ai le même problème
Indice 4
Ajouter un commentaire
3 Réponses
Réponse la plus utile
@singgsirya iFixit does not yet a guide for this. Use the one from here to replace your screen. Since we do not know where you are located, I suggest an online search for a replacement screen within your part of the world.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Indice 1
Display change
And power bottom change
Indice 0
1 commentaire:
I'm going with the assumption you meant "button" rather than "bottom", because the phrase "power bottom" has a whole different meaning in this country than what you probably intended.
If you need to change the electrical part of the button including the click dome, use this guide.
https://www.nadiemellamagallina.com/en/m...
If you want to replace the physical part of the button that you press, use this one.
And see @oldturkey03's answer for the guide to replace the screen.
par
Mobile no the wrking
Indice 0
1 commentaire:
Mobile display no werke
par
Ajouter une réponse
Singg Sirya sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 32
Total : 1,064
