Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repair documentation for the 3rd generation 11" iPad Pro (model numbers A2377, A2459, A2301, and A2460). Released May 2021.
Water damaged iPad Pro M1 works but the display is black
Hello,
As per the title I have an iPad Pro that has suffered water damage. While the device still works, sounds can be heard etc, the display shows black but the backlight works. I have tried reconnecting the cables but to no avail. Is that more likely to be a board or LCD panel issue? Tips and suggestions are welcome. Thanks
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire:
Hey :) I have exactly the same problem on my iPad Pro 10.5". What did you do? Did it turn out to be the panel or was it a board issue? Best, Michael :)
par
Ajouter un commentaire
1 Réponse
Water damage is tricky. It's hard to tell if you will have residual issues from a "repaired" water damaged device. However, in your case, just focusing on the issue at hand, I would bet replacing the display would fix the issue. Now, there is a chance that someone else is shorted causing no display but, in my experience I have "fixed" device by replacing displays after water damage.
Indice 0
Ajouter une réponse
And sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 287
