Charging cable is not getting connect
When I plugged in the white light for charging indicator blicks and then get off.
Battery status show IDLE in boot manager.
@sarwarpatil you didn't tell us if it blinks in a pattern. Use the SM to determine what the blink codes means. This could be a bad battery. Try this:
• Remove the Battery, the AC Adapter and any other device connected to the system. Press and hold the power button depressed for 60 seconds. After that reconnect your AC adapter and your battery. Try to turn your computer on.
• Press F2 on boot-up to enter the BIOS screen. Check the adapter status in your computers BIOS to confirm that there is no issue with the adapter.
• Run the diagnostics to check for any hardware issues.
You can download teh service manual for your computer from here use that for any further troubleshooting.
Battery health is showing excellent
@sarwarpatil what about your AC Adapter? What does the BIOS tell you about that? Any errors in your diagnostic?
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 6
Total : 41
