Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lancé le 20 septembre, le smartphone 2019 d'Apple est doté d'un écran OLED de 5,8 pouces, d'une caméra arrière à triple objectif et d'une autonomie de batterie considérablement améliorée. Il succède à l'iPhone XS.
Cornice schermo scollata / detached screen bezel
Per togliere lo schermo si è scollata la cornice metallica che lo tiene al telefono. Apparentemente non c'è niente di rotto ma lo schermo non si accende più, avete suggerimenti? Grazie.
To remove the screen, the metal frame that holds it to the phone was unglued. Apparently there is nothing broken but the screen does not turn on anymore, do you have any suggestions? Thank you.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
I wouldn't think that removing the frame would cause the screen to fail, but along the bottom of the screen are delicate electronic circuits that I'm guessing the frame was protecting. I suspect that in the process of separating the frame from the screen, some of those circuits got damaged. About all you can do at this point is replace the screen and hope that's the problem.
Of course you checked the connectors carefully with a magnifying glass and a bright light for any bent or broken pins, correct? And looked at the flex cable for any tears or damage? Wouldn't hurt to clean both sides of all the connectors with 90% or higher concentration isopropyl (rubbing) alcohol and recheck.
Indice 2
1 commentaire:
Thanks for your reply, the phone works fine with a new screen. But I'd like to recover the original. I don't see any circuitry under the bezel though. I thought it could be a silver glue weld that holds the frame glued to the screen, on the right side that has come unstuck. I ordered the specific glue, as soon as it arrives I will try. Thanks for collaboration.
par
Ajouter une réponse
olleto49 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 193
