My laptop is not starting charging
@mobilezone8947 start off with the simple things. First you want to check your power supply. Make sure it has the proper voltages. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. After that you need to check and see if your motherboard even gets power. For that of course, you need to open it up. This teardown Packard Bell EasyNote TK87-JO-050PL Teardown can help you with this. Post Some good pictures of what you see. That way we can see what you see Ajout d'images à une question existante
You should also consider replacing the battery. A depleted battery can no longer be charged.
Tutoriel
Difficulté :
Très facile
2 - 5 minutes
Tutoriel
Difficulté :
Modérée
10 minutes
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 3
Total : 25
