Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La quatrième génération de Fairphone, fabriqué par l'entreprise sociale du même nom. Sortie en octobre 2021.
Why can't I extract the display?
Approximately two months ago, I accidentally partially destroyed the display of my Fairphone 4, and after various struggles in terms of buying and selling, today I finally managed to get a replacement ready to be installed.
I prepared myself and started the official video available on YouTube. Fully charged battery, screw container, cloth, plastic card, and screwdriver at hand. Everything is ready.
So, I begin, initially struggling a bit with the trickier screws, but soon I find the method. However, it doesn't seem to be enough because when I try to remove the screen, even though all eight screws have been removed, the bottom part, below the SIM slot, remains firmly in place.
And that's the story of how all the waiting has been wasted so far.
I also tried to disassemble the rest, but the bottom part, secured with six silver screws, even after removal, doesn't alleviate my difficulty, while the side part has hexagonal screws, so a crosshead screwdriver doesn't seem to be enough. Now I have reassembled everything except for the eight screws attached to the screen, to see if someone responds today.
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire:
The video I'm referring to is this one:
https://youtu.be/SUJERxuYGLI?si=JA-kqw6M...
par
Ajouter un commentaire
2 Réponses
@carmelo40109 we are not sure what video you are following. I would have suggest that you use the guide from here Changement écran Fairphone 4 Going by that, all you should need is a Phillips #00 screwdriver. Post some pictures of what display you have and of the screws etc. that are giving you trouble.
Ajout d'images à une question existante
Image iFixit
Tutoriel
Difficulté :
Très facile
2 - 5 minutes
Image Fairphone 4 Écran
Tutoriel
Difficulté :
Facile
10 - 20 minutes
Indice 0
I finally solved it:
all I had to do was to apply more force when extracting the body at the bottom.
I followed the procedure and everything went as planned.
Whoever has the opportunity can now close the topic.
Indice 0
1 commentaire:
Choose this post as the answer, and the topic will close.
par
Ajouter une réponse
Carmelo sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 22
Total : 553
