Oil or grease leaking from bottom of stand.
Is this an easy fix or should I look at replacing it? 15 yr old
Thanks,
Mike
Thanks,
Mike
I know this is an old thread, but maybe my comment will be useful to someone.
When the grease in machine leaks out, it can be because the grease has broken down and thinned out, also the screws that hold the machine together may have worked loose. I would first try tightening the screws by removing the drip ring, and turning the unit over (lay it on a towel) and tighten the Philips head screws you see around the perimeter. If they need tightening, and it hasn't lost more than a tablespoon of grease, you are probably good to go.
Otherwise, you will need to open the machine and replace the grease, and inspect the gasket carefully to decide if it needs replacing.
you have to open the machine and change the grease
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 15
Total : 384
