Aller au contenu principal
Pour réparer ensemble - Je crée un compte
PC de bureau économique fabriqué par Acer, sorti en 2006.
If I turn on the PC after few minutes the PC will suddenly turn off
If I turn on the PC after few minutes the PC will Off
Répondre à cette question J'ai le même problème
Indice 5
1 commentaire:
Ami me parece en ahorro de energía pero no me da opción bde nada la verdad no sé k le movió mi niño me ayudaría x fabor. Gracias
par
Ajouter un commentaire
2 Réponses
If your PC is turning off suddenly after being on for a few minutes, there could be several potential causes for this issue. Some common reasons include:
1. Overheating: Check if your PC is overheating. Dust accumulation or a malfunctioning cooling system can lead to overheating, causing the PC to shut down to protect itself.
2. Power Supply Issues: Faulty or insufficient power supply units can result in sudden shutdowns. Make sure your power supply is functioning correctly and providing enough power for your components.
3. Hardware Problems: Malfunctioning hardware components like the CPU, RAM, or motherboard can cause sudden shutdowns. You may need to check and potentially replace these components.
4. Software or Driver Issues: Outdated or incompatible drivers, as well as certain software conflicts, can lead to system instability. Updating drivers and ensuring software compatibility can help.
5. Virus or Malware: Malicious software can cause unexpected shutdowns. Run a thorough antivirus scan to rule out malware.
6. Power Settings: Check your power settings in the operating system to ensure that your PC isn't set to automatically shut down after a certain period of inactivity.
7. Power Surges or Outages: If you experience frequent power surges or outages, it could be causing your PC to shut down. Consider using a UPS (Uninterruptible Power Supply) to protect your PC from power fluctuations.
8. BIOS Settings: Incorrect BIOS settings can lead to instability. Ensure that your BIOS settings are correctly configured for your hardware.
If you're not comfortable diagnosing and fixing these issues yourself, it's advisable to seek help from a professional computer technician who can perform a thorough inspection and troubleshooting to identify the exact cause of the problem.
Indice 0
Confirme
Se a fonte não tem capacitor estufado, pasta térmica do processador, memória
Indice 0
Ajouter une réponse
Adhi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 39
Total : 1,174
