Aller au contenu principal
a budget friendly smartphone. identifiable by SM-M105F / SM-M105G.
شحن الهاتف بطيئ جداً لكي يملئ بالشحن ؟ charge très lentement
TRanslation
The phone is charging very slowly to fill up
Traduction
Le téléphone se charge très lentement pour se remplir
Répondre à cette question J'ai le même problème
Indice 2
1 commentaire:
Is the phone charging too slow to fill up?
par
Ajouter un commentaire
1 Réponse
@shkfmhmdslm there are a few things that can cause this. Start off by check this Samsung site for the general checks. It addresses closing background apps, deleting third party apps, checking the charger etc.
If that does not help with your phone, you will have to check the charging board. Ultimately I would start by replacing the battery and the charging board. Since iFixit doe not yet have a guide for this, use something like this video to work on your M10.
If even this does not change your phones issues, we will have to work closer with jumper ways on the charging circuitry on the main board. This will be a lot tougher since it requires you to have a good rework station as well as some good skills doing micro soldering etc.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://fr.ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is war on Entropy!
Translation
@shkfmhmdslm il y a plusieurs choses qui peuvent causer cela. Commencez par consulter ce site Samsung site pour les vérifications générales. Il aborde la fermeture des applications en arrière-plan, la suppression des applications tierces, la vérification du chargeur, etc.
Si cela ne suffit pas pour votre téléphone, vous devrez vérifier la carte de charge. En fin de compte, je commencerais par remplacer la batterie et la carte de charge. Puisque iFixit n'a pas encore de guide pour cela, utilisez quelque chose comme cette vidéo pour travailler sur votre M10.
Si cela ne résout pas les problèmes de votre téléphone, nous devrons travailler de plus près avec des cavaliers sur le circuit de charge de la carte mère. Cela sera beaucoup plus difficile car il faut avoir une bonne station de travail ainsi que de bonnes compétences en micro soudure, etc.
Pendant que vous travaillez sur votre téléphone, prenez beaucoup de photos. Une fois que vous avez terminé, prenez ces photos et créez un guide pour iFixit. Cela aidera la prochaine personne qui aura le même problème que vous. C'est facile et amusant de créer ces guides. https://fr.ifixit.com/Guide/new La communauté iFixit appréciera.
La réparation est la guerre contre l'entropie !
ترجمة
@shkfmhmdslm هناك بعض الأشياء التي يمكن أن تسبب هذا. ابدأ بالتحقق من هذا موقع سامسونج للفحوصات العامة. يتناول إغلاق تطبيقات الخلفية، وحذف تطبيقات الطرف الثالث، والتحقق من الشاحن وما إلى ذلك.
إذا لم يساعد ذلك مع هاتفك، فسيتعين عليك التحقق من لوحة الشحن. في النهاية سأبدأ باستبدال البطارية ولوحة الشحن. نظرًا لأن iFixit ليس لديه دليل لهذا الأمر حتى الآن، فاستخدم شيئًا مثل هذا الفيديو للعمل على جهاز M10 الخاص بك.
إذا لم يغير هذا حتى مشكلات هاتفك، فسيتعين علينا العمل بشكل وثيق مع طرق التوصيل على دوائر الشحن على اللوحة الرئيسية. سيكون هذا أكثر صعوبة لأنه يتطلب منك أن يكون لديك محطة إعادة صياغة جيدة بالإضافة إلى بعض المهارات الجيدة في القيام باللحام الدقيق وما إلى ذلك.
أثناء عملك على هاتفك، التقط الكثير من الصور. بمجرد الانتهاء من ذلك، التقط تلك الصور وقم بإنشاء دليل لـ iFixit. سيساعد ذلك الشخص التالي الذي يعاني من نفس المشكلة التي تواجهك. من السهل والممتع إنشاء هذه الأدلة. https://fr.ifixit.com/Guide/new سيقدر مجتمع iFixit هذا.
الإصلاح هو الحرب على الإنتروبيا!
Indice 0
Ajouter une réponse
شكااف محمد سالم sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 164
