Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Machine à café sortie en 2013. La Keurig K40 est une cafetière compatible avec les K-Cup.
Keurig “lights of death blinking.” Pump stopped working.
After doing research, I’ve come to the conclusion the pump may be shot; but just looking for confirmation. Turned it on this morning, pump went to pull water, acted slower than normal. Did the whole “put out half cup for a cup” thing. Tried one more time and the pump finally stopped. Now it won’t do anything when turned on. I left it for a minute or two, then the “Add Water, Heating, and Medium Cup” lights came on…I’ve checked the filters, check valve, needles, etc. Everything seems to flow the way it should. Saw a “method” that said to press and hold the Med cup button while everything is blinking and then the system would purge itself (or at least that’s what it sounds like it does), but all that happens when I do that is kill those lights and turn the power light back on (it’s off while the others are blinking). Is there anything else that can be done?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
I had this problem. Different model. It was the pump and when I lifted it a little it would work. I ended up putting a piece of Lego under the pump and it has been working for 8 months
Indice 1
1 commentaire:
Lifted what? The whole coffee maker? How did you lift the “pump” and how did you find it?
par
Take it back to the store that you bought it from, we’re on our third one, but that fix works ever time
Indice 0
Ajouter une réponse
Joshua Humeston sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 22
30 derniers jours : 104
Total : 6,947
