Aller au contenu principal
Guides for the eMotorWerks (now Enel X) JuiceBox EVSE
JuiceBox Pro 40 from 2016 emitting six beeps
I have a JuiceBox Pro 40, PCB 8.14.1, Manufactured June 24 2016. It is emitting 6 beeps repeatedly. For a while it took about a minute after plugging in my Leaf for it to start charging. Now it has stopped charging and is emitting 6 beeps after powering it on, pauses and then repeats.
According to
https://support-emobility.enelx.com/hc/e...
this error is:
"This error is an internal system fault - usually related to pilot
signal generation. Check that your control pilot (CP) signal pin isn't
shorted. Contact Support if this code persists."
I have the box open and see where the small wire from the J1772 plug goes to the circuit board. I don't see any burned out components yet.
Any ideas of how to try to repair this?
Edit: Adding Images
PCB Image:
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
Tagging @falconfour as he seems to be the expert on this.
par
Ajouter un commentaire
1 Réponse
Oo... 6 beep! I think that one was added specially to cover an error with the -12v (negative 12v) failing. It was a relatively common issue with v8.12, due to an undersized capacitor (spec'd for 16v, but physically too small, and loved to crack) that shorted the -12v rail. v8.14 was the board that started getting the firmware that addressed (raised a fault for) the issue with v8.12, but the capacitor was no longer a problem on that board. It did, however, use the same DC-DC converter design that v8.12 used - and it was problematic.
In your case, the -12v DC-DC converter may have died. How dirty do you want to get your hands? I made a significantly improved version of the converter circuit (based on a MUCH simpler chip, designed for the task... can't believe we didn't know about that part in 2014 when this circuit was being developed). I haven't listed it for sale, but if you're willing to get your hands dirty, I might just post them up and make a guide for it.
Can you add a photo of your board, and I can point to where to measure voltage?
Indice 0
1 commentaire:
Added PCB image to original question.
I am comfortable desoldering a few components and replacing them. If I need to desolder more than 8 connections I may not want to put that much effort into the fix or trust my soldering skills to be up to the task.
par
Ajouter une réponse
sputicus sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 184
