Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le HP ProBook 450 G4 est un ordinateur portable fabriqué par la société électronique Hewlett-Packard. Le HP ProBook 450 G4 a été commercialisé en 2016 et a le numéro de modèle Y8A06ET#ABF.
Cooling Fan is running high speed but laptop did't turn on
My laptop shuddenly keep shut down...when i start it cooling fan spin in high speed but laptop didn't turn on..If by chance it turn on..it auro shut down again..
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi @mdhasan68494
Try a full power refresh in case it is a corrupted BIOS and check if that resolves the problem.
Here’s the procedure:
a). Disconnect the charger from the laptop if connected.
b). Disconnect the main battery from the motherboard.
c). Remove the RTC battery from the motherboard.
Here’s the maintenance and service guide for the laptop. Go to p.66 and p.77 to view the necessary pre-requisite steps and then the procedure to remove the battery and the RTC battery. Unfortunately with your model you will have to remove the motherboard to access the RTC battery.
When the RTC battery is removed measure its voltage. If it is <2.6V DC replace it. The battery type number is on the battery itself (CR2032 perhaps?).
d.) Reinsert the RTC battery (or its replacement, usually +ve on top as marked on the battery).
e). Reverse the above steps to re-assemble the laptop.
f.) When the laptop is completely re-assembled, connect the charger and try to turn on the laptop.
If it starts OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been completely reset back to its default settings. Once the date and time have been adjusted the message won’t appear the next time that the laptop is started.
If you had previously changed any user defined settings in BIOS to suit whatever specific hardware configuration that you had for the laptop, then these will have to be set again.
Indice 1
Ajouter une réponse
Md. Hasan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 10
Total : 252
