Aller au contenu principal
Can't regulate heat
Cannot regulate the heat
Update (11/23/23)
Whirlpool Model ACE244XSO The heat will vary 10+ degrees------ up and down without moving the thermostat setting. Probably the thermostat but I haven't found one for it.
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
Hi @calvinwiles,
What is the make and model number of the Air Con unit?
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi @calvinwiles
There are two thermostats in the air con unit, Item #10 and #31 airflow and control parts diagram
Temperature control thermostat Item #10 is part # WP1185753 (supplier examples only).
Item #31 is part # 4388458 but I can't find any online. This one looks more like a safety cutout thermostat for the heater given its location, rather than a room temp control thermostat like Item #10. If you suspect it is the problem, check if there's a different part number on it or a make and model number and search online using that information
Indice 1
Ajouter une réponse
Calvin Wiles sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 112
