Aller au contenu principal
The iOpener is an insulated, heat-retaining bag that can be heated in a microwave and used to transfer heat to the adhesive along the edge of an iPad or similar device.
20 questions Voir tout
Can cold temperature damage it?
Since there is a special liquid in it, can it be frozen? If so, it won't be damaged? I am afraid, because if i order it, it will be stored in parcel machine, which is located outside where is cold.
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
@lankerst how cold is cold ;-) ? Excellent Question
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
No, it won't damage the iOpener. The iOpener is like an icepack/hotpack.
Indice 2
1 commentaire:
@jri_creator is about right. The iOpener contains Glycerol. So let's say iFixit had the glycerol mixed with water at a common 64/36 or a 2:1 solution, the freezing point will be in the -40 deg C (-40deg F :-) region. Even then it will not freeze but turn into a very thick and viscous liquid. Also, there is minimal expansion only, so the risk of rupturing is low. Check it out.....:-)
Ind. Eng. Chem. 1925, 17, 9, 924
Publication Date:September 1, 1925
https://doi.org/10.1021/ie50189a017
par
Extreme temperatures can destroy anything I will comment my real answer on this in a moment
Indice 0
1 commentaire:
Yes most likely but only VERY cold or warm temperatures
par
Ajouter une réponse
LanKerst sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 84
