Ice maker inlet tube keeps freezing up GE PFSF2MIXAWW
I just got this fridge second hand, I turned it on and got it down to temp before connecting the water. It wasn’t allowed to freeze outside during the move. It has made four or five batches of ice, now the inlet tube in the freezer keeps freezing up, it freezes right where it pours into the cup and into the mold. I thawed it with a hair dryer, it made one batch, now that tube has ice in t again, it freezes in the tube shape and the even freezes in the shape of the water flowing into the cup. The filter is out, the bypass plug is installed it’s place. The previous owner was on a well with some iron, I’m feeding it with RO water at 45 psi. The shape of the icicle sort of look maybe the valve is not closing all of the way? Thoughts?
I have thawed inlet tube inside the freezer 2 more times, each time I do, it will make another batch of ice at some point, then freeze up again. I have tried turning the power off for 15 seconds, turning it back on, 3 cycles of the paddle, then waited at least 5 minute and it did not force a cycle. After thawing it will run a cycle eventually, then freeze up again. Should I replace the inlet valve? The water dispenser works fine so I have water at least to the valve and through the valve to the water dispenser, it does flow to the ice maker once, then freezes like maybe the inlet valve doesn't close all of the way?
par Wilsonsk
