Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations de réparation et de démontage du smartphone Google Pixel 8 Pro, sorti en octobre 2023. Identifié par les numéros de modèle G1MNW (NA/AU), GC3VE (UE, Inde) et GE9DP (Japon).
How to replace the rear assembly.
I need to replace the rear assembly and the screen on my Pixel 8 Pro. The Screen replacement tutorial is there, but the rear assembly replacement tutorial is not. Is there ANY guidance?
Répondre à cette question J'ai le même problème
Indice 3
Ajouter un commentaire
1 Réponse
The back panel is what all the components screw into. The best thing to do would be to follow the teardown and put all components back into a new frame.
Indice 0
2 commentaires:
The teardown didn't match the device. The backplate includes the thermal sensor. The battery removal strip is useless, use a thin plastic card (I used the iFixit guitar pick tools and then a hotel room key)
The screen replacement arrived with both an adhesive template to lay the adhesive onto the backplate and ALSO adhesives premounted to the back of the screen. Not sure if one should use both or just one.... 🤣
par
it sure does SUCK that not only does google not make & sell the replacement nfc flex cable like its available $15 for pixel 7 pro but they made a whole back glass assembly with the nfc n wireless charging flex cable attached for $172 but still no instructional video can be found ANYWHERE ONLINE as far as i can tell so far
7sell
par
Ajouter une réponse
Marc Aniballi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 18
Total : 1,802
