Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sharp - AQUOS 42" 1080p LCD HDTV
Sound but no picture
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
@ibrahimhanafi we need to make sure that your TV is a Sharp LC-42D62U
or if you just picked it as a device.
par Partager
Ajouter un commentaire
1 Réponse
Réponse la plus utile
It is most likely a backlight issue. Try to use the torch on your phone and shine some light in an angle onto the screen when the TV is turned on and see is you have a picture.
Indice 1
1 commentaire:
@ibrahimhanafi just to elaborate on the excellent answer by @honakrisi turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Ajout d'images à une question existante for that so we can see what you see. It is possible that this is either a power board or a T-con board issue
par Partager
Ajouter une réponse
Ibrahim Hanafi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 11
30 derniers jours : 31
Total : 326
