Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Télévision commercialisée en 2012.
Is this white-washed screen caused by a faulty T-Con board or panel?
I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Réponse la plus utile
@peterraj yes, it could be a T-con board issue but I do not like the difference between the left and right side as well as the other anomalies. If you can get a T-con board for a decent price give that a try first. While you replace it, check the LVDS cables for corrosion, tears etc. Post some pictures of your boards with your question so we can see all of it and possibly find a solution Ajout d'images à une question existante
Indice 1
9 commentaires:
Hey oldturkey03, thank you for the response. I will upload some pictures of the boards in a day or so. One more question in the meantime. My TV model is c70le735x and the T-Con board is DUNTKF778FMF8. I can't seem to find the full part number on the board though. Any idea where is it on the board?
Also, can I use the T-Con board from the c70le735u model instead of the c70le735x model?
Thanks a lot!
par
@peterraj possible but I can't make out the numbers on your T-con board image. Trying really hard to make out what it says in the top left corner. The RUNT........parts :-)
par
@oldturkey03 Hello again @oldturkey03 . I left this matter as it was and attended to some medical problems. The TV has been sitting at one corner as it was back then and I thought I could work on it this time. I managed to get the numbers on the board that you could not read. Let me know if there is anything else you need. Appreciate it greatly and my sincere apologies!
par
@peterraj let me refresh my thought process on this and I'll try to find out more about the boards. Hope all is well medical wise :-)
par
@peterraj what was I hoping for? Schematics! Well, that is not going to happen :-) Why would any OEM even consider supporting self repair? It'll cut into their profits.
Once more, we are between a rock and a hard place. For now, the only other way to determine if that is the issue would be by replacing it. See if you can get an inexpensive, even used board, and see if that makes a difference with the washout. It is a RUNTK4910TP T-Con board and the DUNTKxxxxxx number is the Sharp part number.
par
Voir 4 commentaires en plus
Ajouter une réponse
Peter Raj sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 49
Total : 890
