Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de réparation, démontage et informations de diagnostic pour l'iPad Apple de troisième génération avec 4G, disponible avec 16, 32 ou 64 Go de stockage. Sorti en mars 2012. Identifié par les numéros de modèle A1430 (GSM, AT&T) ou A1403 (CDMA, Verizon). Les réparations nécessitent l'utilisation de chaleur et de faire levier avec précaution.
Smart Cover Magnets on the new iPad
Was wondering if the magnet configuration on the new iPad is the same as the one in iPad 2. My keyboard case features a smart cover and is supposed to sleep/wake the iPad when the keyboar case is opened or closed but it no longer does that with the iPad. Any insight as to why it might not work anymore? Thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
5 Réponses
Solution retenue
No, they are not the same. I have the Otterbox for the New iPad and while the magnets worked on my iPad 2, they do not for the new one. I have flipped the magnets over to change polarity and just like that it works perfectly now.
Indice 1
Réponse la plus utile
Apple has switched to using a different type of sleep/wake sensor in the new iPad 3. This new sensor is sensitive to magnetic polarity (the sensor in the iPad 2 is NOT sensitive to polarity). I have proven this in an HD video demonstration at my blog:
http://markshangout.com/blog/2012/3/17/i...
If you get a third-party case with a magnet in the cover that has the needed polarity facing the wrong direction, that case will work properly with the iPad 2 but it will NOT work properly with the iPad 3.
Obviously, manufacturers were not aware that Apple would be using a new and different sensor in the iPad 3. Thanks to my blog post, the word is quickly spreading and manufacturers will be fixing their cases accordingly.
Indice 3
if your case doesn't perform sleep/wake: Take a small piece of a thicker refrigerator magnet and test it. If it works, glue it to the inside right edge of outer flap, about 2 1/2 inches from the top of your ipad 2 case. A 1 inch by 1/2 inch size or smaller works best, but too small or too thin (ie magnets on back of business cards) may not have enough magnetism.
Indice 2
Thanks neddy this is a very nice solution
http://smpstroubleshooting.com/
Indice 0
Where can I buy 2 small magnets for my daughter's Outer I Pad holder? Thank you sincerely for your time!!!
MJ de los Santos
mjdls007@gmail.com
956 373-1775
Texas
Indice 0
1 commentaire:
My iPad Air case stopped attaching to the screen and switching off , bought a new case same . Chap on YouTube said stick the case to the fridge or other metal panel , then stick the screen to same, bingo it worked case is doing its job . Hope this helps people.
par
Ajouter une réponse
Rudy Frederic sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 41
Total : 11,131
