Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Canon Powershot A590 IS est un appareil photo numérique compact de 8 mégapixels doté d'un zoom optique 4x et d'un écran LCD de 2,5 pouces.
How is the battery hatch door replaced?
The flip door over the batteries and memory has been damaged. I have a new door, but it came with no directions. I need to know how to remove the old door and install the new door.
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
Ajouter un commentaire
1 Réponse
Solution retenue
The door is held to the front assembly via a small round pin. you will have to use a very small pindriver (a small nail might just work too) and some needle nose pliers to remove it. Watch the small spring that is in the middle of the hinge. A bit tedious and it does require some good eyesight and dexterity. Hope this helps, good luck.
Indice 2
1 commentaire:
It does not appear to be enough room to use the pin driver.
par
Ajouter une réponse
Sherri C sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 8
30 derniers jours : 19
Total : 2,481
