Both brewing options pump the same amount of water
Hi. After cleaning/descaling the machine, both brewing size options pump the same (larger) amount of water. Is there a fix for this?
Try resetting to factory settings: Switch it Off, then On again and press and hold the "Lungo"-button for 5 sec. (The right one). The button should flash three times. The machine will heat up as before - and hopefully the issue has disappeared. Here a Video.
Thank you; that was what it needed 🙂
Well done! Small cause, big effect. ;-)
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 39
