Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sorti en 2021, le Lenovo Ideapad Gaming 3 15ACH6 est équipé d'un processeur Ryzen et d'une carte graphique NVIDIA GeForce. C'est un ordinateur portable de gaming d'entrée de gamme.
How do I replace my keys?
My E and R key are failing from time to time, so i want to clean them, but I'm afraid to break anything in my computer
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
you will have to buy a new keyboard cleaning them is possible but very tricky most likely a very used keyboard
Indice 0
@alistairmoran @bnuyo the keyboard on this model is part of the upper case. You may find one that is separated, however, you will have to remove the old one form the top case. It is held in places by a lot of plastic "tabs" coming of the top case. Once you got it removed you will have to convert all those plastic tabs to holes that will take very small screws to hold the keyboard. It is most likely easier and less prone to failure, if you replace the top case if you wan tot change the keyboard.
This is not to say that you can't fix the keycaps on your computer. Take a look on here and see if that will help you out. Different model but the keycap replacement should be very similar It may help us if you post some good pictures of what you got going on there with your E and R key Ajout d'images à une question existante
Indice 0
Ajouter une réponse
Bnuyo sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 16
30 derniers jours : 67
Total : 1,664
