Aller au contenu principal
Pour réparer ensemble - Je crée un compte
L'iPad Pro 11" de deuxième génération est sorti en mars 2020 avec les numéros de modèle A2228, A2068, A2230 et A2231.
iPad Pro 11” not powering on or charging
Good evening. My iPad Pro 11 (2nd Gen) will not power on or charge. I see a 0.5 amp draw as soon as a charger is plugged with the battery disconnected.
There’s an IC (343S00235) that is getting extremely hot as soon as the charging cable is plugged in. I see no obvious signs of failure of any other component or any other hot spots.
Any ideas? IC failure or am I missing another culprit?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
I hooked a power supply to the board and got zero amp draw. I kept the power supply hooked up and plugged the charging cable in and amp draw went to .090 and stayed there even when the cable was disconnected. However, no heated components were located. Any other ideas?
Indice 1
1 commentaire:
Have you tried starting the Ipad while the supply is connected?
par
Have you tried to power the board with a power supply? Maybe its just a small capacitor, thats causing a short on a line. The Ic can get hot because if you add the charging cable some current ist going through the ic towards the short. But thats just a guess. Best way is to give around 4v to the battery connector, check the current for a short and then find on what line the short ist (instant short means on a main power rail, so check them in diode mode). Then you can give voltage to the shorted line and check what component is getting hot now. If its still the ic, you need to replace it.
Indice 0
Ajouter une réponse
JustTryN sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 44
Total : 1,157
