Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de réparation, démontage et informations de diagnostic pour la première génération de la manette PlayStation 5 DualSense de Sony, qui succède à la série DualShock. S'identifie au numéro de modèle CFI-ZCT1W et à la carte mère modèle BDM-010.
Do you have info about led blinking and the meaning of it?
I have a controller that blinks just three times orange when connected but I haven't found why or what does it means
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
4 Réponses
Solution retenue
Coming back with great news, the sticks was wrong replaced with PS4 Dualshock hall effect, this was the first problem, the second was the entire mother board with solder flux, after replace with the correct and new ones sticks and cleaning all the controller, he returned to his best!
After a few researches, these problem in general is a short circuit, that can be occurred by any reasons as ribbon cables, solder flux, excessive dirt ...
Here to help in case you need
Indice 1
Réponse la plus utile
I recently bought a DualSense with these problems. After opening it, I saw that the analog sticks had been replaced with Hall Effect analog sticks and I suspected that some track was broken.
I removed the entire board and the flat cables along with the analog sticks and nothing seemed broken, but the motherboard is dirty with solder flux.
I'm going to clean it well with isopropyl alcohol and get back to you.
Indice 2
@sebastianc37681 If your controller is one of those DualSense controller that was shipped from Poland, then there is a known issue with those. The 3 blinks are indicating that there is a connection issue on the inside of your controller. Time to open it up and to make sure that all the ribbon cables are properly seated and that there is not anything that can create a short etc, Once open take a couple of good pictures and post those with your Question. That way we can see what you see.
Ajout d'images à une question existante
Indice 1
Afficher le contenu de l'image :
Indice 0
2 commentaires:
I don’t know what’s wrong here
par
You had the same issue of the three times blinking light?
The dualsense dont turn on without the battery
par
Ajouter une réponse
Sebastian C. sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 31
Total : 2,797
