Hi @pietervdd,
An intermittent charging problem could be due to a faulty DC-In jack.
Not booting could be due to a discharged battery as it cannot be charged.
What can sometimes happen is that the centre +ve connector in the jack, fractures internally and this opens the power path, between the charger and the motherboard.
Try connecting the charger to the laptop and then gently and slowly try to move the charger's output cable plug, up and down and side to side, inside the jack and check if the charging light comes on occasionally.
If it doesn't come on at all, you may have to use a DMM's (digital multimeter) Ohmmeter function and check the DC-In jack for continuity from its input to its output connection on the motherboard. Both the +ve inner connector and the the -ve outer ring connector of the jack. Alternatively use the DMM's voltmeter function and check that there's 20V Dc on the jack's motherboard connection when the charger is connected - see image below for test points
If the jack is faulty it cannot be repaired, it has to be replaced. Search online for Asus Rog Strix G513IE DC-In jack to find suppliers that suit you best.
Regarding the cmos battery, nowadays a lot of laptops don't have a separate cmos battery anymore as the function previously performed by the cmos battery i.e. 3V DC voltage to maintain the BIOS settings when the laptop is off, is now being done by a 3V power tap off feed from the main battery in the laptop.
If you wish to perform a power refresh to reset the BIOS etc, disconnect the main battery from the motherboard (you don't have to remove it, just disconnect it) and then press and hold the laptop's Power button for 30 seconds and release. Then reconnect the battery to the motherboard etc.
(click on image)
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
