earbuds not charging in case
My jabra earbuds have suddenly started to not hold a charge.
They were aupposed to be charged by the case, but this not happens, even with the charger connected to the wall.
They only charge to some 20% and then stop. Which ia like 30 mins of use.
When I put them in the case a led should flash according with a color according to how much charge is left (red green yellow), this doesn't happen.
As well, the external led on the case should indicate the charge left in the case, it only flashes green.
(Only purple, when I tried changing the system language to make a firmware update, which did not solve the problem)
I tried resetting the buds, resetting the charger, changing the charger cable and checking voltage, all was suggested by jabra support.
Do you have any other suggestion, other than replacing the charger?
Thanks,
1 commentaire
jabra elite 3 is not charging
par Rahman
