Aller au contenu principal
Pour réparer ensemble - Je crée un compte
A 32" Roku TV released by TCL in 2018.
No image black screen
Répondre à cette question J'ai le même problème
Indice 14
13 commentaires
par
@edwinlombeh have you tried the steps listed in the answer?
par
the television does not turn on, but the power on light
par
No display only stay on
led indicator
par
Tidak ada gambar pas pakai sate box
par
Voir 8 commentaires en plus
Ajouter un commentaire
2 Réponses
Réponse la plus utile
@cristinejo80172 you forgot to tell us if you have sound. Next turn your TV on Then use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obviously damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Ajout d'images à une question existante for that so we can see what you see. It is possible that this is either a power board or a T-con board issue.
Indice 5
5 commentaires:
@oldturkey03 I have the same issue, and did the flashlight in a dark room.
Looks like a backlight issue. Any guides on how to replace it and what parts would be needed? Thank you!
par
yes me too can i get a guide on hoe to fix it
par
@rubimosqueda I bought new LED strips from Ebay.
And then followed these two guides from a youtuber.
https://www.youtube.com/watch?v=I32MBlbR...
https://www.youtube.com/watch?v=QdxSHeQF...
par
Full black image
par
@venu72785 what have you checked and what have you already tried?
par
No enciende, estaba funcionando y se apagó y no prendio
Indice 0
Ajouter une réponse
cristine joy catuboran sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 34
30 derniers jours : 183
Total : 5,001
