Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Motorola One original, à ne pas confondre avec le One Power ou le One Action. Numéro de modèle XT1941.
White light blinking at the side of the frontal speaker when charging
After my phone got wet, I let a long time letting it dry (not on rice don't worry). But after that happened, when I try to start my phone, it doesn't start, and when I try to charge it, at the side of the frontal speaker a white light blinks.
I sent it to a repair shop but they gave me a high cost to fix it (as always). I declined to try to repair it by myself. What should I check for in my phone? And what I might have to change? Thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
You need to open the critter and check for and clean any corrosion, if you are lucky, that will set things right:
We don't have a tear-down on this device, so I'm putting a You-Tube video link below showing you how to disassemble and clean it. Word of advice, use a soft-bristled toothbrush and do not be very forceful; the SMDs (the tiny Surface Mount Devices) are easily damaged if you get carried away... be gentle. Since we don't have a tear-down on your device you might want o take photos of the process and add them as a guide for others with the same problem. Here's the video link:
https://youtu.be/dLqu45I8j1E
Good Luck. Let us know if we helped you!
Indice 1
2 commentaires:
Is there another one for my specific model? Because this video is from a model that opens from the screen, and my phone has been already opened (well the glass was shattered anyway) from the back...
Edit: Nevermind, these steps are quite simple, I'll just get them going. Thanks!
par
You're quite welcome. Good Luck!
par
Ajouter une réponse
Adrian Zurita Rasgado sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 412
