Le téléphone ne charge pas mes refusé également de démarrer
Le téléphone buel sa flash sa refuses de charge après quand tu allumé
@hermann12213 most common issue will be teh charging port. First check your charger. Make sure it has the proper voltages. Check your charging cable to make sure the connectors are not bend etc. After that, check the charging port on your phone. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Teh Blackview uses a sub-board (charging board) that has teh charging port on it. I'd suggest that you replace that complete board. It is not to expensive and a lot easier then trying to solder a new connector. This is an example of what that board looks like. While you have your phone disassembled, replace the battery as well. that way you will not have to worry about it. Replacing it will also rule it out as a cause for the error.
Since iFixit does not yet have a guide for this, I suggest that you use the one from here If you get stuck at any time during your repair or have a general question about things you find when you disassemble your phone, just post some images with your Question. That way we can see what you see and hopefully help you further.
Translation
@hermann12213 Le problème le plus courant est le port de charge. Vérifiez d'abord votre chargeur. Assurez-vous qu'il a les tensions adéquates. Vérifiez votre câble de charge pour vous assurer que les connecteurs ne sont pas pliés, etc. Ensuite, vérifiez le port de charge de votre téléphone. Assurez-vous qu'il n'y a pas de corrosion, de débris, etc. qui l'empêchent de fonctionner. Nettoyez-le de tout débris, etc. à l'aide de quelques bouffées d'air. Ensuite, vous devez vérifier si votre carte mère est alimentée. Pour cela, vous devez bien sûr l'ouvrir. Le Blackview utilise une sous-carte (carte de charge) sur laquelle se trouve le port de charge. Je vous suggère de remplacer cette carte complète. Ce n'est pas très cher et c'est beaucoup plus facile que d'essayer de souder un nouveau connecteur. Voici un exemple de ce à quoi ressemble cette carte. Pendant que vous démontez votre téléphone, remplacez également la batterie, vous n'aurez plus à vous en soucier. En la remplaçant, vous éliminerez également la possibilité qu'elle soit à l'origine de l'erreur.
Puisque iFixit n'a pas encore de guide pour cela, je vous suggère d'utiliser celui from here Si vous êtes bloqué à un moment ou à un autre de votre réparation ou si vous avez une question générale sur les choses que vous trouvez lorsque vous démontez votre téléphone, postez simplement quelques images avec votre question. De cette façon, nous pourrons voir ce que vous voyez et, je l'espère, vous aider davantage.
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 17
Total : 68
