Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Xiaomi Poco X3 Pro is an entry level smartphone by Xiaomi released March 2021. It is equipped with a 6.67" IPS LCD screen, a 48 MP main camera and runs on the Qualcomm Snapdragon 860.
My phone is not charging but charger working
While I connect to the charger my phone is not charged
Répondre à cette question J'ai le même problème
Indice 9
2 commentaires
Hp tidak mengisi
par
@wardintolinggi follow the instructions from my original answer. Let us know what you find out.
Translate
@wardintolinggi ikuti instruksi dari jawaban asli saya. Beri tahu kami apa yang Anda temukan.
par
Ajouter un commentaire
4 Réponses
Réponse la plus utile
@vaishnavidevi could be a bad battery, bad charging circuit or a bad charging port. Having run into this a lot over the last few month, the easiest is to actually replace the charging board. It is relatively inexpensive and replacing it is fairly straightforward. Also, check the flex cable from the charging board (sub_board) to the main board for any tears corrosion etc. Once you have the board replaced I would also replace the battery, since you have the phone open. That way you only have to do that one time.
Since ifixit does not yet have a guide for that, use something like this video to replace the parts.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War one Entropy
Indice 4
6 commentaires:
Hello I changed bord and battery but still not charging what I need to do now help me please thank you
par
@gabrielgab45028 did you check/replace the flex cable from the charging board to the main board?
par
How it's look 😁? Flat one or thin one
par
I think it's flat one just ordered to change 😉
par
gini loh bro kawan kawan
saya punya hp poco x 3pro udah lama dan masalah ini bukan dari flaxsibel ataupun papan board pengencesan harus ganti baru, intinya yang rusak itu ic pengecesan yang ada di board mesin
par
Afficher 1 commentaire en plus
@vaishnavidevi, In my case it was a loose connector. Remove the back cover and check the cable which connects the charging port with the mainboard. You need to remove the cover of the mainboard around the camera to reach the connector. For details, see the tutorials, e.g. for changing the battery. It shows all the necessary steps.
Good luck!
Indice 0
Hello, my friend, the problem with your phone is probably from the charging socket or it is dirty and turn it off and on again so that it might be fixed, then clean your charging socket.
Indice 0
Battery Is weak or Charging port dead
Indice 0
Ajouter une réponse
vaishnavi devi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 31
30 derniers jours : 156
Total : 8,108
