Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Compaq Presario cq56 Sorti en 2010
How to check if the Bluetooth device is installed and up to date?
How to check if the Bluetooth driver is installed and up to date? It doesn't appear on my screen
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
@amandalondeka what version Windows are you running?
par
Ajouter un commentaire
3 Réponses
Solution retenue
@amandalondeka has it ever worked for you and did anything happen to it. We also need to know the exact model of your CQ56 since not all of them even have Bluetooth. In that case you would need to get a Bluetooth Network Adapter.
Indice 1
1 commentaire:
Most are probably lacking it, so a lot of the time it's a replacement card :-(. Even the 2 cards with BT are no longer supported due to Ralink being bought out, so there's no new drivers and the BIOS has it's own issues with aftermarket card replacements.
Now, if these did not have a whitelist and weren't new enough to be from the RSA BIOS era (2008 or 2009, maybe 2010-present, strengthened with Intel Boot Guard with a OEM private key stored in the firmware), you might be able to strip the WL out of the BIOS, but I don't want to touch that on a site like that - firmware hacks are too advanced. I mean, maybe you can modify the BIOS to remove the whitelist then flash the EEPROM directly with a RasPi or other tools, but this is why I don't think the discussion belongs here. These are far less secure then the later 2013+ machines where the PK was in the EC and checked against the BIOS (changed when you "hack" the whitelist out). These are not easily directly flashed with the HP software, though.
par
Most of them do not have BT - the CQ56-219WM is absolutely not equipped with it as I had one years back due to a parental ultimatum so I know that one too well. It was a bad spec in every way.
That said, most of them will probably lack it. Your best bet is to look in the SM, and pick up one of the cards which have it, and then add it that way. On a lot of these low end laptops back then, that was the way to add it and know it is present reliably. Now it's so cheap to add it's just part of the WLAN card either as a part of the SoC or added on with a discrete chip finding one without it is a rarity.
I have pulled the cards which have it from the SM:
Broadcom 4313 802.11b/g/n 1x1 WiFi and 2070 Bluetooth 2.1+EDR Combo adapter (BT3.0+HS ready) -- HP Spare; 600370-001
Ralink RT3090BC4 802.11b/g/n 1x1 WiFi and Bluetooth 2.1+EDR Combo adapter (BT3.0+HS ready) -- HP Spare: 602992-001
YOU MUST GET A CARD WITH THE HP VID FOR THESE - 100% OF THESE HAVE A WLAN WHITELIST UNLIKE THE NEWER BUSINESS AND CONSUMER MODELS WHERE THEY CUT THAT BS. IF IT LACKS A HP SPARE STICKER OR IT IS NOT ON THE LABEL, IT MAY NOT WORK!
Indice 0
It’s always frustrating when Bluetooth devices don’t work as expected, especially when you’re unsure whether the issue lies in the installation or outdated drivers. Before diving into troubleshooting, it’s helpful to understand how operating systems manage Bluetooth connectivity and device updates. Windows, macOS, and even Linux handle these processes differently, with built-in tools to check driver status and update compatibility.
Indice 0
Ajouter une réponse
Amanda Londeka sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 16
Total : 377
