Why is my Xbox shaking + making Loud noises when attempting disk read
My Xbox loads up fine, but when I load a disk in it, it will have problems reading it, and it will shake violently and make loud noises. I've checked the discs, and they are clean and unscratched. Does anyone know what the problem could be? (It's also missing the screws to the disc drive and main cover courtesy of the previous owner, and I think that may be the problem)
5 commentaires
This is for sure an issue with the disk drive, have you tried cleaning it?
par Maple
I believe it is a problem with the disc drive because the problem only happens when it attempts to read a disc. Also yes I have tried to clean it.
par Turtlelaw
It could be an issue with the rubber bands inside the disk drive, would you be able to check what condition they are in?
par Maple
@criedwareinit do you mean the drive belt band? If so I've already replaced it
par Turtlelaw
@turtlelaw Did you also check if anything within the drive that might be vital for it's functionality (such as the mechanical parts) are broken or missing?
par Maple
