Selfie camera blurry and front camera shaking and making noise
After replacing display and battery the front camera is making noise and is shaking and selfie camera is blurry.
Display also doesn't fit perfectly, through it's acceptable.
How do i fix it?
Battery is sourced from amazon and display from aliexpress.
More context: i used hot air gun(60-90°) to disassemble and followed videos on youtube for replacement.
I didn't notice any kind of damage except for few missing screws on display metal plate.
Iphone otherwise works.
The sound of camera sounds like shutter played too fast repeatedly.It wont focus when taking picture.
Selfie camera doesn't make sound but is blurry.
Edit: microphone doesnt work while calling over wifi and sim card tray wont read sim.
I guess i killed this phone.
Edit2:
Will this be a problem when i reassemble the phone?
I decided to change charging connector since the microphone didn't work iz appears to me, even though i placed the cable as instructed in ifixt guide, it doesn't sit right with the logic board.
Edit 3: after replacing the lightning connector and and replacing the front camera/ proximity sensor flex cable, and double checking all the cables if they sit right, the iphone is stuck in endless boot.
Logo appears, smartphone shut down, logo appears smartphone shut down.
Any idea how to fix this?
(@dadibrokeit sorry to bother you, but you look like you could help me save this phone)
4 commentaires
If you can open it up and give us a more detailed view of the inside we might be able to help give a more right diagnosis. Based on the limited information however, it can sound like a loose connection or a damaged ribbon connector to the camera. It might also be as simple as apple having locked functions because they have a tendency to software lock features with "non authentic" parts.
Ajout d'images à une question existante
par Markus Norstrøm
Hi! Updated.
Im pretty sure i f*cled up something up and hope its not software lock..
As far as i can see i see no damage except for the display not fitting right.
par Vicktory
@vicktory I'll refer you to this guide so you can double check if you have done the fitting of the screen right.
Remplacement de l'écran LCD et de la vitre tactile de l'iPhone 8 Plus
par Markus Norstrøm
@markusnorstroem i think i did it right.. followed the ifixit video and read the guide.. i put the iphone in dfu mode to try fix the bugs.
I'll try swapping the cable as mentioned below by @dadibrokeit
par Vicktory
