Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La Galaxy Watch Active2 est une montre connectée de Samsung Electronics. Son numéro de modèle est SM-R825, SM-R830 ou SM-R835 et elle a été commercialisée en août 2019. Réparer votre Samsung Galaxy Watch Active2 avec ces tutoriels.
My watch screen opened up
I went swimming and i put the watch next to the pool but it fell into the pool, the screen popped out and when i let it dry it still doesnt turn on what can i do to fix it or is it gone forever?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Depending on how it "opened up". If the screen separated completely with the watch I suggest you replace the watch completely. But even so if it slightly opened and water entered the system repairing would be of no use
Hope it helps
Indice 0
2 commentaires:
It opened up but still attached with little droplets of water which i managed 2 remove
par
Try charging it (make sure it is dry) if it turns on you are good to go(if the screen can easily stay there with no movement). If it is still not sticking back , I suggest opening it up, gently apply heat to the screen to make the adhesive sticky and try putting it back. If it doesn't work I suggest you get some of that adhesive (when I get the name I will inform you) and try putting it on.
par
Ajouter une réponse
I5m4il7 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 23
Total : 728
